Re: Using Quick Start IH 504
Posted by mkirsch on November 21, 2011 at 05:20:45 from (64.80.110.75):
In Reply to: Using Quick Start IH 504 posted by keithre on November 20, 2011 at 14:35:49:
The answer to the question is, none.
"Quick start" and glow plugs is a baaaaaaaad combination.
If you haven't blown the tractor up yet, either you're very lucky, or your glow plugs don't work, or you haven't been using your glow plugs because you didn't know you had them.
