Re: MD split/engine swap
Posted by CNKS on November 21, 2011 at 07:27:01 from (216.144.104.128):
In Reply to: MD split/engine swap posted by hatrick on November 20, 2011 at 18:35:44:
The clutch and flywheel are easy to remove, just heavy. I work alone and removed the engine from my Super M last week. Rolled front forward using a splitting stand. Removed clutch, flywheel and rear plate. Supported engine with engine hoist and took bolts out of front mounts. Lifted engine up and out with the help of a long screwdriver to aid in clearing the front mounts. Also removed the head before removing engine. The engine itself is very heavy MD probably heavier--the lighter you can get it the better. There is no reason to slide it out the front or back, just lift it with a hoist.
