Re: 1961 Int'l B275 Diesel low Oil pressure
Posted by leroy in ne on November 21, 2011 at 09:50:12 from (67.63.105.230):
In Reply to: 1961 Int'l B275 Diesel low Oil pressure posted by Johan_smyth on November 21, 2011 at 08:32:04:
now that engine is cooled off check oil, if it seems very thin smell it for diesel, pump seals do go bad and leak fuel into crankcase, thinned oil will not build pressure, will go past rings and be burned but should still indicate over full condition. will leave for the experts input as i'm only a back yard mech with out much experiance.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
