Re: 1961 Int'l B275 Diesel low Oil pressure
Posted by Jimb2 on November 21, 2011 at 13:56:17 from (174.115.9.174):
In Reply to: Re: 1961 Int'l B275 Diesel low Oil pressure posted by Johan_smyth on November 21, 2011 at 09:51:59:
Hi John, on the BD-144 engine the most common
failure is the diaphragm on the fuel lift pump on
the right side of the engine. This lets Diesel fuel
into the crankcase causing oil dilution. The less
common failure is the oil seal on the drive shaft of
the fuel injection pump.
If either of these parts fail, the crankcase oil
should be thin and smell of Diesel fuel.
JimB
