Posted by Wardner on November 21, 2011 at 20:26:31 from (4.154.239.110):
In Reply to: 3pth to fast hitch posted by Jason Hubner on November 21, 2011 at 19:35:44:
Don't think the 3pth arm are strong enough and, depending on what implement you are attaching, you might need to drill another hole in the arms.
I'd approach this problem by comparing what is different between the 504 Fast Hitch and the 504 3pth hardware. You could get either system from the factory.
If all you need is the wishbone plus sockets, lift links, and belly pivot and don't care about draft control, that might be a better solution. Goto the CaseIH on-line parts book to do your research.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in
... [Read Article]
Latest Ad:
[More Ads]
