Re: Do Cracked Head Repair Liquids Work?
Posted by Mike1972chev on November 22, 2011 at 16:49:43 from (99.75.48.186):
In Reply to: Do Cracked Head Repair Liquids Work? posted by 400D Guy on November 22, 2011 at 14:39:21:
My first question: Is this a recent rebuild??? second question: is this a 400 diesel????
If not:
If you are seeing anti freeze,it is getting time to actually repairing it.Unless you ABSOLUTELY cannot do it,it is time to start to think about dis assembly.
There is some errosion going on that the "bars leak" will only put off so long.It aint worth trashing a crankshaft over it.(Coolant is VERY abrasive on a bearing surface.)
For starts,pull the valve cover off and see if you can see any coolant around the head bolts.
Give me MORE detail,and I will give you a BETTER answer.
