Re: Detergent oil in a cruddy engine
Posted by pete 23 on November 22, 2011 at 17:26:39 from (74.32.238.142):
In Reply to: Detergent oil in a cruddy engine posted by sgtbull on November 22, 2011 at 12:28:23:
With the bypass oil filter system a M uses, you could plug it and the oil pressure to oil gallery will be unchanged. IH didn't start using a full flow filter until the 560's etc and even then they have a bypass for cold oil or plugged filters.
