Posted by soundguy on November 22, 2011 at 21:06:46 from (184.4.159.38):
In Reply to: my posted by firemanracer17 on November 22, 2011 at 20:58:15:
recheck needle and seat for float valve, check float adjustment, and that flaot is not hanigng up, also make sure flat is not heavy or has a hole in it..
to check for a pinhole in a float, microwave a jar of water till it boils.. remove frommicrowave and using needle nose, plung float into water.. water will heat the flaot, and if there is a pinhole it will make a microstream of bubbles from t he hole.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
