Re: Detergent oil in a cruddy engine
Posted by sflem849 on November 23, 2011 at 05:26:33 from (69.197.84.39):
In Reply to: Detergent oil in a cruddy engine posted by lblock on November 22, 2011 at 12:28:23:
There is a bypass on that oil filter that is designed to allow oil flow to the engine in case the filter gets plugged.
