Posted by rustyfarmall on November 23, 2011 at 08:07:36 from (216.248.71.224):
In Reply to: my "new" farmall 300 posted by sgtbull on November 22, 2011 at 20:58:15:
Allan, the all steel needles have been obsolete for several years now. The Viton tipped needle is much better. You just need to clean it and the seat really good before installing. I use aerosol carb and brake cleaner. A little shot of silicon spray lube after cleaning doesn't hurt either.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
