Re: BN transmission
Posted by Hendrik on November 23, 2011 at 11:28:44 from (194.53.253.51):
In Reply to: BN transmission posted by RalphL on November 22, 2011 at 09:29:36:
Just where the final drives attach to the transmission case there is a bearing carrier (one on each side), attached with three capscrews to the transmission case. These bearing carriers carry the bearings on which the differential turns. Pull these carriers and the entire differential will fall out. IMPORTANT NOTE: between the bearing carrier and the transmission case are some shims. Left and right are most likely different, so mark the bearing carriers and keep the shims with their corresponding carrier. The shims determine A) the axial play of the differential and B) the back lash of the conical gears.
Both transmission shafts need to be pulled from the rear. On the input shaft (top) a bushing or a hub (cannot remember) is pinned to the shaft. Remove that pin and the coupler at the flywheel side and the bearing at the flywheel side.
HTH, Hendrik
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
