that we got at an auction and extended the sides down and boxed in a set of fast hitch couplers (cut off just behind the couplers) from a junked 656. Tacked them up under the three point connectors using the fast hitch drawbar to hold them in alignment and mounted it to the 806 to check the clearances. The fast hitch couplers stick out from the 3 point connections far enough to use the latches and low enough to clear the 3 pt arms when centered. We rigged up sway chains to keep it centered. Dad could then use his 2 point blade and other implements he had from his 560 on his 806 without buying or selling anything.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
