Re: 340 thermostat sending unit - threads
Posted by Owen Aaland on November 23, 2011 at 20:12:56 from (216.47.35.187):
In Reply to: 340 thermostat sending unit - threads posted by Harold Hubbard on November 23, 2011 at 18:02:07:
The threads in the head are NPT. The threads in the adapter will depend upon which gauge you have. IH used a couple of different adapters and an after market unit may be different from either of those. The gauge should have come with the correct adapter aand if it had NPT on the end the adapter is already on there. You will need to remove the old from your hear and use the new one.
