Re: Detergent oil in a cruddy engine
Posted by CoopertownBob on November 23, 2011 at 22:41:19 from (74.51.5.124):
In Reply to: Detergent oil in a cruddy engine posted by sgtbull on November 22, 2011 at 12:28:23:
I never use any of the "trick" stuff to clean the inside of the engine. Instead, I always substitute one quart of ATF for one quart of oil at each change. Keeps the inside of the engine clean enough to eat off of. I have also used it to clean out engines with more sludge in them then oil, but only after pulling all pans, covers etc. and scrapping everything off I could reach by hand. Then I add fresh oil, filter and the ATF. Check the oil condition DAILY until it looks like the stuff running in the sewer, then change it again and repeat. Eventually, it comes out clean and there have been no other issues. I guess doing it this way might cause leaks, but since the first thing I did was R/R all covers, I replaced the gaskets with new ones at that time and it has not been an issue for me.
