Re: my new farmall 300
Posted by TomH in PA on November 24, 2011 at 07:00:33 from (184.5.168.77):
In Reply to: my posted by firemanracer17 on November 22, 2011 at 20:58:15:
If it increases speed then dies it sounds like it's starving out rather than flooding.
I'd check for a good flow of gas into the carb, pull the line and little screen that's inside the card at that end and see if you get a good flow. Rust in the tank blocking flow is a common problem that causes what you describe.
