Gene, I set the carb linkage as I was taught to: disconnect the governor arm from the carb linkage. Push the governor [throttle] linkage full open. Hold the governor and carb linkage in full open and adjust the turn-buckle on the carb linkage until the two pin holes are in line. On the throttle slop: On the hand lever it is dead from idle until about half-way before the engine responds to the throttle increase. And then it is not a slow increase. It basically will jump from idle to half throttle. I believe it is getting a little worn. I've been around this tractor all my life, and it has always had slop in about a quarter of the throttle lever, which my grandfather told me was about right. I do know that I can take up the play by adding either shims or a longer collar at the end of the throttle rod where it connects to the governor on the mag side. But, will this effect my top end speed?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
