Posted by Tom Fleming on November 24, 2011 at 17:31:31 from (206.193.250.146):
In Reply to: tractor engine heater.. posted by mike paulson on November 24, 2011 at 04:56:22:
Mike, what tractor are you putting this on? Is this a diesel? glow plugs? Are you having trouble turning it over, or trouble getting it to fire?
If it is gasoline only, I would invest in an oil pan heater. If diesel, then a coolant heater would be my next choice. reason for oil pan heater on a gasser is to reduce the starting amps to crank it over. Unless it is really frigid, gassers do pretty well. If a diesel, I would want the block itself with the combustion chambers to be up to a reasonable temp.
Just my $.02 worth. I don't use a heater on any of mine, and I have started by F-20 at -10 without much fuss, and that is hand cranking it. I know in really cold weather, my H gets a bit fussy, but if I am careful on how I use the choke, she usually will fire up.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
