Re: drawbar
Posted by Janicholson on November 24, 2011 at 19:40:41 from (71.221.25.117):
In Reply to: drawbar posted by ajdeereman on November 23, 2011 at 18:11:16:
The M drawbar is ticker and has a largwer pivot pin. The bends to place it at the pull point are different. The U shaped drawbar support, attached to the axles will interchange, but the M is (as noted below) thicker. Pulling point should be made to match the H length unless needed as noted below. Jim
