Re: c-123 in a Farmall A
Posted by Tom Fleming on November 24, 2011 at 23:36:17 from (206.193.250.146):
In Reply to: c-123 in a Farmall A posted by Machine249 on November 24, 2011 at 19:01:14:
Jim is spot on. depending upon how hard you are going to work it, you can get away with the thermo syphon system and eliminate the water pump. If you are going to work it hard, I would NOT suggest that. going with a C-123 and a water pump, you will need the Super A taller grille and also the gas tank mounts so that you get the clearance you need for the hood.
There are bore kits available for the C-113 engine that take it to what amounts to a C-123, and of course, you won't have the water pump.
