Re: M Brake shaft bearing play
Posted by Tom Fleming on November 24, 2011 at 23:39:42 from (206.193.250.146):
In Reply to: M Brake shaft bearing play posted by Loren in Iowa on November 24, 2011 at 18:19:33:
Absolute best way is to take the deck off, and that is for lots of reasons. Not sure how hard you work this tractor, but if that bearing is worn out, there is a good chance that other things inside are fairly worn also.
If it were mine, and I wanted to put her back into shape, I would remove the deck, really more tedious of a job, than a complex or difficult one.
IMHO.
