Even though you probably WILL have to rebuild the carb, I wouldn't have that done until you know know for sure. if it was stored dry, it could be perfectly fine.
Have you tried cranking the engine at all? By hand?
I'd pull each plug and put a little oil in each cylinder, just for good measure.
Assuming it's not stuck - I'd pull the valve cover and just watch everything as you (or someone else) hand cranks it (be sure it can't start). Just to be sure no valves are stuck open.
While you're in there, might as well pour a little oil over the whole valve train.
I would also go under the assumption that the clutch plate is stuck to the flywheel. Make sure you're in neutral when starting, and if it starts and the gears are grinding when trying to get into gear, don't force the issue till you fix the clutch.
Draining the tank is a given, but also drain the bowl on the carb. If you're lucky, the previous owner did that when they put the tractor away.
I wouldn't toss all the gas, it's too expensive. Just mix it with fresh stuff and it should still be ok, but only after you've got everything running well.
Also - since you're draining the tank - do it from the carb end of the gas line - and while you've got it apart, check the screen in the carb inlet fitting. It's a good time to get any crud out of that.
You should also clean up the points - a little 400 grit sandpaper to shine them up.
I'm sure I'm forgetting other little details - but I think you'll be fine. Those engines are so forgiving it'd probably fire right up on the first crank without doing anything to it.
This post was edited by JRSutton at 07:15:24 11/25/11.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
