Re: Need help with first start-up in 2 years!
Posted by old on November 25, 2011 at 07:56:39 from (209.86.226.40):
In Reply to: Need help with first start-up in 2 years! posted by BigTone on November 25, 2011 at 06:46:30:
Only sat 2 years I would probably jump on it and see if it starts. If it does start go for it. If it does not start I bet the points need cleaned or replace and then go for it
