Posted by Janicholson on November 25, 2011 at 17:39:44 from (71.221.25.117):
In Reply to: Fast Hitch Problem posted by WI-Ed on November 25, 2011 at 02:37:07:
Assuming a hitch cylinder on the SC, Lift the hitch (on either) and block it with a jack or wood shoring at a normal height with pressure off of the cylinder. Remove the hydraulic lines and cap/plug them both at the cylinder, and at the hoses. Now remove the blocking or jack so the hitch is free to go down. If it does go down some, the issue is packing in the piston. If it stays up, the problem is in the valving, or check valve. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
