I did a lot of them from the rear with out taking cover off. It isn't a lot harder to align that bull gear to axle from the rear than it is with cover off. Of course, cover off you can clean things up a lot better and check a lot more things. Another thing to remember, that ball bearing on the shaft may be fine and the up and down movement you get is from the inside end of the shaft which is supported only by the gear in the differential. If that is the case a new bearing will not help you. You probably have a groove worn in the brake drum causing the leak or seal is not in straight or partially collapsed. It doesn't take much to mess up a seal. I never use two seals but do place the seal at a depth where it will be riding on a good unworn part of the brake drum.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
