Re: Re: Suicidal Super C
Posted by TomH on August 30, 2000 at 16:35:26 from (206.99.145.152):
In Reply to: Re: Suicidal Super C posted by Fudd on August 29, 2000 at 19:27:10:
If it has an external resistor, replace it. Might be shorting out as it heats up, extra current would then heat up the coil.
Post A Followup
: Re: Re: Re: Suicidal Super C
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
