Re: Need help with first start-up in 2 years!
Posted by Jason the Red on November 25, 2011 at 19:56:38 from (99.188.104.132):
In Reply to: Need help with first start-up in 2 years! posted by BigTone on November 25, 2011 at 06:46:30:
I agree with most of the guys here, put some good gas in it, check fluids, see if it will start. You will probably be surprised.
Steve also has a very good point about your local Case/IH guy. The only thing you are ensuring is that you pay an arm AND a leg.
If you really want to own a tractor and restore and maintain it yourself, you are gonna have to learn about the different components. The carbs don't have much too them, crack her open and take a look. Have your manual handy, if you do have any questions this forum is very helpful as well.
I would only mess with the carb if the tractor doesn't run or runs poorly, which even then may only be an adjustment issue.
