Re: Got the Head off the 400D
Posted by Janicholson on November 26, 2011 at 15:13:10 from (71.221.25.117):
In Reply to: Got the Head off the 400D posted by 400D Guy on November 26, 2011 at 14:12:31:
The head can be rebuilt at most automotive machine shops it is no different than other heads. Make sure they are told to maintain the valve head/seat depth in the head. If they are allowed to sink into the pocket, the compression will be so low it will not start or run well. Very important.
Using various tools and removing the waterjacket cover, it is possible to clean it up.
I would heat the studs red with a Oxy Acetylene torch. Let them cool to about 300 degrees then put a wax candle on the base to let wax get into the threads, then begin to work them to remove. They just look weak. Jim
