Re: IH 140 plowing
Posted by DeltaRed on November 26, 2011 at 16:14:43 from (71.215.111.150):
In Reply to: Re: IH 140 plowing posted by Erik Dekeyser on November 26, 2011 at 05:03:22:
Eric,you need to clatify.Does the disk have 2 'gangs' with 8 blades each,or 4 'gangs' with 4 blades each?A disk is measured in "feet",not # of "plates".Alse as "tandem";or single disk.
