Re: 400 blown head gasket - need help identifying cause
Posted by pete 23 on November 26, 2011 at 16:25:18 from (74.32.238.142):
In Reply to: 400 blown head gasket - need help identifying cause posted by lug_wrench on November 26, 2011 at 16:14:34:
Every failure I see on your picture looks to be
right where the head gasket crosses over from
block to the flange of the sleeve. This would
indicate that the sleeve flange is protruding too
far over the top of the block. Book says something
like .004 max but I personally always felt that
was too much. I have seen an engine with new
sleeves this summer that were .008 above block and
it leaked immediately. A friend of mine was
working on it and He had a couple of choices.
Machine block with sleeves installed for flush
sleeve, cut counter bore for sleeve or machine the
flange of the sleeve down. He did not want to pull
the sleeves out so he had the block machined down.
This method IH always uses of the head gasket
crossing off and back onto the sleeve flange is in
my book not one of their better ideas. Always
questioned it but normally works ok if protrusion
is slight.
