Farmall 350 fluids question
Posted by Jim Weber on November 26, 2011 at 18:02:41 from (24.111.86.164):
I would like to know what I should use in my Farmall 350 for the 7 gallons of fluid/oil...
I have a slight leak in the axle seals, and plan to use the tractor winter and summer, so wasn't sure what to use. There are grease certs on the axles. Are they to help seal those potential leaks?
One person told me to use Hi-Tran for all the fluids on the tractor. I was concerned that it would run out the seals on the axles.
My second question is if someone had a good wiring diagram for a Farmall 350 12 volt.
Thanks for your help,
Jim
