Re: 400 blown head gasket - need help identifying cause
Posted by Tom Fleming on November 26, 2011 at 19:03:35 from (206.193.250.146):
In Reply to: 400 blown head gasket - need help identifying cause posted by lug_wrench on November 26, 2011 at 16:14:34:
Do you happen to remember what you had the head torqued to? Each of your failures is right where the gasket is the thinnest between the cylinder sealing ring on the gasket, and the water port. All of those failures show heat erosion.
I agree with checking the sleeve height above the deck, but this also looks like a head not propery torqued down.
