Re: 400 blown head gasket - need help identifying cause
Posted by lug_wrench on November 26, 2011 at 20:05:27 from (209.180.64.9):
In Reply to: 400 blown head gasket - need help identifying cause posted by lug_wrench on November 26, 2011 at 16:14:34:
Head bolts were torqued to 110 ft-lb per the manual. The manual also says the sleeves may project a max of .006 but should not be below the surface.
