Posted by D Slater on November 27, 2011 at 09:30:44 from (184.15.30.71):
In Reply to: New sleeves? posted by Jim Paterson on November 27, 2011 at 08:51:40:
Assuming the piston rings would be sealing the same on 3-7/16 pistons and the 3-3/8 pistons. You you won't see a lot of HP difference between the 3-3/8 aluminum step head pistons and most regular aftermarket overbore types. Also depends what type piston and the final compression you end up with. Also the head pistons are used with. H tractors used heads with different size combustion chambers. Most times a head casting # is found in the area under the valve cover to identify the head. Yes the overbore sleeves fit the standard block.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
