Re: super M oil pump question
Posted by Bob M on November 28, 2011 at 16:09:07 from (67.240.168.45):
In Reply to: super M oil pump question posted by Pat Connors on November 28, 2011 at 13:55:17:
Pat - There is no "wrong" way to install the idler gear. However you MAY be able to identify which way the idler was originally installed by looking for wear marks on the face of the drive gear teeth then installing the idler gear so its wear marks match with the drive gear.
But the pump will work fine with the idler gear installed either side up.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
