Re: mw clutch on m
Posted by D Slater on November 28, 2011 at 16:44:01 from (184.15.30.71):
In Reply to: mw clutch on m posted by jim warehime on November 28, 2011 at 14:40:11:
If its the drum the clutch plates go in? After everything is out of the drum look for the retainer with 3 screws at back of drum. After the seal retainer is removed you should find a drum retaining ring in a grove on the bull pinion shaft. remove the ring and the drum comes off. To remove the bull pinion gear and shaft and the bull pinion housing the bull gear inside the rear end needs moved out of the way.
