Re: Re: Farmall M Clutch pedal shaft bushing
Posted by john d on August 30, 2000 at 20:24:12 from (152.163.206.199):
In Reply to: Re: Farmall M Clutch pedal shaft bushing posted by Haas on August 30, 2000 at 19:44:27:
Keep your antenna up, and maybe you'll run across someone with a vertical milling machine that would be willing to put the thing in a vise and run a milling cutter or big drill through it so you could press in a bushing.
Most of those things aren't loose because of a lack of a bushing, but lack of GREASE!
Post A Followup
: Re: Re: Re: Farmall M Clutch pedal shaft bushing
