Posted by CenTex Farmall on November 28, 2011 at 22:11:30 from (166.147.65.80):
In Reply to: Sleeve Gouges posted by 400D Guy on November 27, 2011 at 11:09:59:
To me it looks more like a piece of trash went through it at some point. I've torn down engine before that had broken rings and there was no damage from that. In one case I pulled down a running engine that had a fracture that went through piston and both compression rings and there was no cylinder wall damage.
Normally the ring exerts some outward pressure against the cylinder. If broken for some reason, that outward pressure is lost and the ring no longer seals but will not necessarily tear up the cylinder. The ring is now just along for the ride.
The clearance Jim was referring to is the vertical ring clearance. The clearance _behind_ the ring is a bit more.
The problem you have now is that the further you go into the engine the more and more little things you will find that will bug you even though the engine will still run. First the head gasket problem and now you find this. I've been down this road many times myself!
It may be possible, if the cylinder wear does not exceed limits and if the piston is not damaged, to smooth the gouges then run a hone through this cylinder and put new rings on it and go. It's hard to tell from the photo how fresh the damage is. Was the compression good on this one? You may be able to live with it until you're ready for a major overhaul. However, if you end up taking the block out to for machine work for the head gasket issue then it would be wise to check all the cylinders and pistons for wear and consider your major overhaul at this point.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
