Re: Super A snow plow?
Posted by Red Dave on November 29, 2011 at 10:04:00 from (66.216.141.163):
In Reply to: Super A snow plow? posted by David Lampman on November 29, 2011 at 09:37:43:
If IH made it, I expect that it has pieces that extend back to the drawbar or final drives that transmit the pushing force back to a place that is designed to take it.
I would strongly suggest that you do not push against the front end very hard, like when pushing snow. These tractors do not have a frame, they use the engine block as a structural member to support the front end. It can be broken. They have been broken. It can ruin your block or the steering box.
