Re: AUSCO--LAMBERT DISK BRAKES ON FARMALL H
Posted by Zachary Hoyt on November 29, 2011 at 11:02:30 from (173.86.123.82):
In Reply to: AUSCO--LAMBERT DISK BRAKES ON FARMALL H posted by S2710 on November 29, 2011 at 10:57:41:
Newer Hs have a drum with splines, it is one of the things that was changed along the way. I have several drums I am looking to sell for $5 each, I could put 2 in a flat rate box if you'd like them.
Zach
