Re: Super A snow plow?
Posted by Stan MI on November 29, 2011 at 11:58:18 from (76.247.147.184):
In Reply to: Super A snow plow? posted by David Lampman on November 29, 2011 at 09:37:43:
I had a plow similar to what you are looking for on my SA for many years. (Sorry no photos)
It used a long A frame that mounted on the draw bar as the push support. Lift was a pully that was mounted by a piece of channel steel connected to where the cultivators mount and lifted with the standard hydraulics. I never trusted stacking snow with it because I though lifting the blade while pushing snow would be too much for the lift arm. It did plow snow very well.
