Re: New Info on the 400D Cylinder Gouges
Posted by rustred on November 29, 2011 at 15:22:13 from (74.200.18.156):
In Reply to: New Info on the 400D Cylinder Gouges posted by 400D Guy on November 29, 2011 at 12:58:37:
looks like carbon scratches.those comp. rings look like they were seating poorly in the second pic. are those 2 oil rings in the same groove? piston should be ok if ring land clearance is ok.what is that shiny in the btm. of cyl.?
