cub clutch
Posted by whig on November 29, 2011 at 15:35:23 from (76.118.14.146):
Instaled a new clutch in the 47 farmall cub and it won't release.I have adjusted the fingers and the free play four or five times all diffrent ways and no goodGrinds going into gear once you get it in as long as you keep the pedal down you can go through all the gears. Is it possible I put the disc in backwards.The release bearing seems to be loose on the shaft.You can reach in the hole and move side to side about 3/16 of an inch.any thoughts on this one? The old clutch worked fine but I had to change the rear main seal so figured I'd do the clutch while I had it split. Should have left it alone.(if it ain't broke leave it alone)
