Posted by D Slater on November 29, 2011 at 17:03:17 from (184.15.30.71):
In Reply to: Tranny problems posted by mark20 on November 29, 2011 at 15:14:40:
Can't remember all the serial # breaks without looking them up. But yes the w6 parts can be used. You need to use the w6 input shaft, 4&5 sliding gear 2&3 sliding gear and 3&4 double gear from the counter shaft and install in the M at the least. Some or all(can't remember) will change the 3rd or 4th speed in a M. Or you can use all the W6 transmission gears in a M as a set. Some change 1st, reverse, 3rd or 4th speeds. Or you can put the w6 transmission housing with gears complete in a M. Ring and pinion will be different and speed up ground speeds. Several ways parts can be swapped around between the two, if you post the serial # of both with what you would like to change I can probably tell you how to go about it.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
