Re: tank type block heater -chapter 2
Posted by LJD on November 29, 2011 at 17:48:42 from (67.142.130.44):
In Reply to: tank type block heater -chapter 2 posted by Dr. Bert on November 29, 2011 at 17:19:16:
Tank heaters get sized by size of cooling system.
An M holds 6 gallons, so that calls for a 1000 to 1500 watt heater.
You can buy heaters with thermostatic temp control or just with an overheat control. If it has the temp control, you can't go too big. It will just heat up faster.
If you always plan ahead and plug in the night before, the small heater is fine.
If you sometime need your tractor fast, it's zero degrees outside and you did NOT plug in the night before, get the bigger heater. 1500 watt.
