I am sure a lot of 460's were made into (almost)560's engines when they were majored. Need more than the crank though as the piston pin hole is in a different location to accomodate the longer stroke. Far as starting, compression and cranking speed is everything. The piston height over the block varies a lot in these tractors thus changing the comp ratio from one tractor to the next one coming off the assembly line. Thus, one starts better than another one. Later ones with the IH midget nozzles are better starters also. If any head work was done , valve recession is crucial, again for comp ratio. No one thing fits all on diesel engines. IH changed pre cups one the 460 also at one time but reverted back as they did not get the desired results.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
