Re: New Info on the 400D Cylinder Gouges
Posted by Janicholson on November 29, 2011 at 18:37:13 from (67.72.98.45):
In Reply to: Re: New Info on the 400D Cylinder Gouges posted by 400D Guy on November 29, 2011 at 17:26:14:
You will not be putting a reliable engine together
with that sleeve. If the piston is good, and cleans
up, the scores in it are Ok. If the ring lands are
good, with new rings and .0005-.001" between the
ring and land, all is well there. Be sure to clean
carbon out of the ring grooves to the bottom to
assure the new rings do not get held out and seize!
LA Sleeve will make a duplicate of the cylinder if
you cannot find one! Jim
