Re: hubs on an H
Posted by CNKS on November 30, 2011 at 06:11:05 from (216.144.104.128):
In Reply to: Re: hubs on an H posted by Tom Fleming on November 30, 2011 at 03:58:12:
I put about 5000 hours in the 50's on an H with 11(12.4)-38 inch tires. They definitely are not too big. This was with a full load most of the time. 10 and 11 inch tires were both sold on them at that time. For heavy tillage, 10 inch is too small. On the other hand 12(13.6) I consider to be too large. We got good traction with 11 inch loaded tires with one set of weights, probably would have been an advantage with two sets. However, the tractor was also used for cultivation, more weight increases compaction.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
