Re: farmall m mw clutch
Posted by D Slater on November 30, 2011 at 18:32:56 from (184.15.30.71):
In Reply to: farmall m mw clutch posted by jim warehime on November 30, 2011 at 17:13:25:
Don't have instructions but just checking to see if you saved the parts on the right that should be there to mount the left brake pedal return spring. Also the sawed off original left brake return spring lever on the clutch shaft. Also the 6 special bolts for the bull pinion housing mounting.
