Posted by NolanJae on December 01, 2011 at 05:19:39 from (156.98.127.101):
So I ordered my new intake and exhaust manifold (aftermarket)for my 460 gasser. the new ones are pretty good except one thing. Put in the heat riser and if you take the gasket out prior putting together the heat riser works like it should. If you put the gasket in the flapper will pass the top casting mark and you can run the weight and heat riser flap from 9 o'clock to 3 o'clock where she closes. I took them back apart and the casting stop for the heat riser flap (vertical) is not down enough to stop the heat riser flap at the 12 noon open position. Took to a weld shop for a bead to be welded on but he wont touch it cause its cast. He thought I should tack a little lip from the old riser flapper onto the new one but were talking adding weight to the end of the flap for only an 1/8 inch of metal. I'm wondering if I can drill and tap a hole in the top of the manifold all the way through and run a bolt down to act as a stopper for the vertical-cold position?
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
