Re: Could someone enlighten me on my H's rear end problems?
Posted by Lmack on December 01, 2011 at 07:53:44 from (74.190.83.193):
In Reply to: Could someone enlighten me on my H's rear end problems? posted by Crazy Red Power in SE-WI on November 30, 2011 at 10:24:07:
If the oil seal in the break housing is leaking it will cause the break to grab with the slightest touch. If the breaks are adjusted so that there is little motion needed from the foot petal to engage the breaks, it may be enough to cause the break to grab in normal operation. Does not sound like anything to do with the rear end unless a bearing is out. That should not happen unless it has been run low on rear end oil. I would take a look at the break before I opened the rear end.
Since the engine is sleeved, fixing the compression problem is not a monster job. Replace the sleeves and pistons and rebuild the head and you are back in business.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
